Engine/Transmission (1994 - 1998) Clutch Torque values
Engine/Transmission (1998.5 - 2002) Crank Position Sensor Tone Wheel
2nd Gen Non-Engine/Transmission Driveline Vibration...
Hey, I am installing a clutch in my 97 and I don't have the torque
specs. Would any of you wild bombers (oop's should'nt say that)
have them for the pressure plate and the flywheel? Thanks Harlan :rolleyes:
pressure plate = (clutch cover) =
5/16 bolts = 17 ft. lbs
3/8 bolts = 30 ft lbs
a little bit at a time in a "star" pattern
Fly wheel = 101 ft. lbs in a criss cross pattern
good luck
Pressure plate
Tardog.
Thanks, that is what I need. My Commings moter book stops at the back of the block.
Thanks agen
Harlan:rolleyes:
Just hook up the big impact gun, crank it to full blast, and squeeze the trigger
for a few seconds... That's what I did, even though I am sure they dont condone it, but oh well. so far, so good!
-Chris-
