Engine/Transmission (1998.5 - 2002) Clutch up-grade
Southbend for sure! match the clutch to your final horsepower goal error on the larger side, or if you pull (truck pull not tow) get a double disk.
good luck,
-Alex
Word of advice... . don't try to go cheap on a clutch. I learned the hard way & bought the Luk... . only got 40k miles although it was hard towing miles. I recently switched to the Southbend 3250 Dual Disc with sprung hub... . it is smoother than the Luk & built to last 500-700K miles if you don't sled pull. If you are planning big power... the DD is rated at 600hp+. Whatever you decide... go Southbend!
Hard to beat South Bend for range of selections and quality - but be sure to be realistic as to any future mods you might have planned, and how you will most typically be using the truck - then give all that info to Peter at SBC - he'll treat you right! ;)
