CumminsAholic
Grandpa's truck... 1996 1 ton 2wd 5 speed (undervalved
) CTD, 150k. Yesterday while driving it something happened. I dunno if it was suddenly or what or if it even made any noise. Anyways, the clutch will not fully disengage. If you start the motor with the truck out of gear it won't go into gear. If you start it in L it'll move with the clutch pushed in. If you start it in 1st it'll stay. You can shift thru the gears if you hit the right rpm range, just like if you'd clutchless shift. I checked the fluid level, it's full. There's also pressure on the petal, just like normal. It's like I need to push the clutch in further, but I can't without hitting the floor. What do you guys think it is? Slave cylinder?? I thought that I remembered a discussion where a plastic bushing in there can crack or break and fall out. If so, where is it? I haven't really looked at anything yet, it has a van body on it and won't fit in a 10 foot door and it's snowing outside. Hasn't snowed here for a month, but of course that's how things go.
TIA
Corey
TIA
Corey
