Clutch
High Idle Problem
well, I had to do it.
I just bought a 93 350, and I was wondering if anyone knows where I can get the pressure plate rebuilt. And maybe where I can buy a new organic clutch disc to replace the stock unit. Thanks.
The way to go is to get a clutch kit. The clutch can be replaced with the same clutch as a NV4500 uses but you need a bolt kit to adapt it.
I have a first gen so I checked into it with SouthBend Clutch a while back. I stocked a couple of adapter kits just in case I got the urge to swap mine. So far the stock (at least the one that was in it when I got it) clutch is holding fine. The truck has injectors and a 12cm exhaust housing at 130k mi.
If you want prices gimme a call or PM. at the HP level of the 1st gen there should be lots of choices. My personal favorite is by far SBC;):D
Later,
Mark
Try Autozone as they carry the stock OEM 13" w/cast pressure plate. Best cluch is the stock cluch. $499 as I just got one 6 months back.
Originally posted by Mark_Kendrick
I promise the best clutch IS NOT the stock clutch. however, the stock clutch may be sufficient for your application.
I second that!:D Drive a truck with a NEW stock clutch, then drive a truck with a used ;) SBC and you will never go back to stock again. Bill
