Engine/Transmission (1994 - 1998) Clutches 101
Engine/Transmission (1998.5 - 2002) oily/greasy slime in turbo
Engine/Transmission (1998.5 - 2002) Boost and FP gauge question.
OK, I guess I’m done making mods for the time being. :D I turned the timing up to 15. It did reduce EGTs but there seems like a very noticeable drop in low end torque, still I’m going to leave it there till I get a new clutch, then I may drop it back a bit to regain some.
I cant afford a clutch now but would like to figure out what one I might want so I know how much I have to save up. :confused: I’ve been reading about the SBC clutches but am somewhat confused. I think I basically understand the differences between the O, OFE & FE. O being the smoothest and lowest capacity, FE being the strongest and grabbiest (is that a word?) and the OFE somewhere in between. Id like to have the best of both worlds of course but given the mods I’ve done and how I use the truck Id probably settle for the OFE unless you guys convince me otherwise. I am confused as to what size I would want 12” or 13”. Apparently 12” is the stock size for my truck. Is the 13” just for the 6 speeds or will it replace mine too? I see mention of replacing the flywheel for the 13”. Is that what I would have to do or is there more to it than that even? :confused:
Tim
See insertions. .
PHP:
OK, I guess I’m done making mods for the time being. I turned the timing up to 15. It did reduce EGTs but there seems like a very noticeable drop in low end torque, still I’m going to leave it there till I get a new clutch, then I may drop it back a bit to regain some.
Turn in the pre-boost fueling screw at 1/2 turn increments to see if it wakes up the bottom end a bit again. You might experiment with different afc positions and the AFC spring tension.
PHP:
I cant afford a clutch now but would like to figure out what one I might want so I know how much I have to save up. I’ve been reading about the SBC clutches but am somewhat confused. I think I basically understand the differences between the O, OFE & FE. O being the smoothest and lowest capacity, FE being the strongest and grabbiest (is that a word?) and the OFE somewhere in between.
How much is your ultimate hp goal? You are likely safe with the OFE as it is over engineered for many bombers.
PHP:
The 12" is fine, but if you tow go with the 13"
PHP:
The 13" is a redrilled flywheel that has the bolt pattern for the p. plate out closer to the outside diameter. The clutch center is stronger. You can also spec a roller bearing, kevlar bushing or oem pilot bearing design depending upon the input shaft nose condition.
Most vendors charge a healty core fee to assure getting a flywheel back. A new flywheel is about $350 from Cummins. You would have to have a machine shop redrill it so the 13" Southbend will mount.
SB also offers the 12 or 13" clutches with the 1 1/4" input shaft vs the 1 3/8" used typically with the NV5600 6 spd.
Good luck
Andy
