CO2 Recall & Lost Mileage
I heard about this issue as well. So before I went to have it done, I monitered the mileage readings on the overhead computer. After the re-flash, it seemed that nothing had changed in my mileage on the way home.
On a day or two later, I went on a 600+ mile trip, and saw a decrease in mileage at the trip computer. Was this a real loss in mileage? Was it head winds? I don't know, because I did not verify it with the fill method.
Several thousand miles later, however, my mileage seems to be back where it was before the re-flash.
I have had some people comment that during the re-flash process, the technician did not input the correct tire size. Or the incorrect rear end ratio. This will definitally change your mileage numbers on the trip computer.
My suggestion is that if you are seeing a big drop in mileage on the trip computer. First, try and verify it with the fill method. If the computer is off, take it to the dealer and verify that they have the correct parameters set. e. g. tire size and rear end ratio.
