CockEyed
Cummins & Coleman
Horton Fan Clutch Survey
Now that I've settled into a nice routine with Ol' Tar Baby it's time to be a little picky. My steering wheel is cocked off to the left about 5 degrees when going down the road. When I first got the truck it wandered around abit but after adjusting the tire pressure most of that has been corrected (after all it's a TRUCK). I was wondering if anyone else has seen the same and if there is a correction or do I need to go see a dealer... . (I hate that).
Bear
Bear834,
Assuming that the track bar is not worn beyond service limits -
You need to adjust the drag link to center the steering wheel. The drag link goes from the pitman arm to the passenger side steering knuckle. It has a threaded adjuster shortens/lengthens the drag link. Adjust it so that steering wheel is straight ahead when travelling on a FLAT (not crowned) straight road. Don't forget to even out the air pressure in your front tires #ad
Brian
[This message has been edited by Brian Meadows (edited 06-13-2000). ]
Thanks for the replies.
With 2300 miles I doubt it's the trackbar but the adjustment to the drag link might just be the answer.
Thanks again.
Bear
Bear,
Good to see you back! Where you been??
On the steering, does the steering wheel sit straight when the tires are straight forward when stopped?? That would tell you if you had to make any adjustments.
2001 4X4 ETH 6 spd, QC, SLT,SB, 3:54, Flame Red, 4" exhaust turbo back, EGT,boost guages
Bear, my steering wheel was also off about 5 degrees after a couple days of driving when new. I just adjusted the drag link myself and now it is O. K. . It was a lot less hassle to do it myself than take it to the dealer. #ad
'98 4x4 12V QCab Auto (ready to BOMB)
Mike
It is off when on flat level ground.
I see there is a TSB out on the steering and I think I will head for the dealer.
Mine is off also... . If it is just as easy as adjusting the drag link then I may take a shot at it also. The truck drives fine but the steering wheel is cocked to the left. It's been that way since I bought it.
98' 3500 Q-Cab 4x4, 5th. wheel with Vac/Hyd trailer brakes.
Mine is also off about 5 degrees to the left. I have been playing with the tire pressure but the wander is still there. My truck is flawless except for the wander and no halo light,even the owners manual says it lights. I am printing out all the treads on these problems and shortly will visit my 5 star and see what he says.
THE ROCK/2001,4X4,SB,AT,SPORT,CL,CAMPER PACKAGE,WHITE,MOPAR MOLDED SPLASH GUARDS,STEELHORSE NERF BARS,BEDRUG LINER,CAB HIGH CAP.
