Engine/Transmission (1998.5 - 2002) code 0336
Allright guys, need some help.
Just got done installing Gauges, during the test drive i lost the Tach for a sec and the Check Engine light came on. There was no hesitation or bucking. Checked for codes and found 0336 for crank positioning sensor. I checked for the connection and that seems tight. After a couple of starts the light went of only to return a few miles later. There have been no performance issues, the Tach works fine and the light comes and goes. I did remove the gauge cluster during install, i dont see what that has to do with 0336.
I just had the same issue with my '99. I thought it was my EZ box but light returned after I removed it. It came back after I installed a new fuel filter. I suspect that I moved some wires around during the filter change... ... . maybe a connection isssue. My truck has also shown no other CPS symptoms. Tach is even ok. I plan on checking all connections and will go from there.
Good luck :D
Replaced the CPS today, my tach started acting up, figured better off replacing now before it gets worse, sensor was only 40. 65 bucks at Cummings there is a 7. 20$ core charge, part #4002066NX
Well... ... I have a CPS on order with my local Cummins dealer. Will be in on Monday. My tach also acted up and with no EZ attached, it couldn't be the box. :rolleyes:
Called dealer and they wanted $237. 00
installed. :eek: I will brave the cold and do it myself! I just hope the sensor doesn't give me trouble coming out or breaks off.
I removed the hold down bracket from the sensor and used a pair of vicegrips to get a good grip and pulled strait back.
I also removed the Oil dip stick, gave a little more room. In case you don't know the bolts on the starter are 12 point 10mm
Good Luck
