Code 0628
Quadzilla Commander
Front axle seal still leaking
My truck--03 2500 4WD Quad cab 305 Cummins I lost power to fuel pump. Threw code 0628 which is " FUEL PUMP RELAY CIRCUIT LOW ". There isn't a marked relay or fuse in the PDC box under the hood. Is there a relay? Is there a fuse?Any answers would be appreceiated. TDragna:confused:
TDragna
Bob4x4---Thanks for the reply. You are correct,the fuel pump ( FASS ) is worn out. I installed it in 4/04 and driven 80,000 miles with it. It is a older model and the brushes are worn out. Easy fix but i decided to go with a new motor & pump. TDragna:D
Strange, the FASS is activated by a relay and that would have had to be open for the truck to set a code. In other words, the truck hooks up to the relay instead of straight to the pump like it did with the stock setup. Did you skip the relay in your install?
