Engine/Transmission (1998.5 - 2002) code 128
2nd Gen Non-Engine/Transmission Where Can I Buy A Replacement PCM
Engine/Transmission (1998.5 - 2002) Skip / stumble under load
A code 128 keeps coming up, check engine lite comes on. sometimes the engine temp is normal, sometimes cold.
If I change the thermostat wha else do I need to do?
2002 24 valve 120,000 miles everything else is fine Thanks
It's possible the ECT (Engine Coolant Temp) sensor is faulty and should be replaced. It's easy to do.
John L.
