Engine/Transmission (1998.5 - 2002) Code 1689 - I think it is the VP44
Engine/Transmission (1998.5 - 2002) K-45 in twin setup
Engine/Transmission (1998.5 - 2002) shop in victorville?
Driving along and it just plain died on I-5 today. No warning, and 30 minutes or so before the fuel pressure was fine in the truck. I think the VP44 just went down. :{ I do get a psi or two from the lift pump, but I am not sure if that is now fried as well. When I first turn the ingition, i get a bump in pressure, but when I bump the ignition, I get nothing. When the VP44 dies does the return open?
Ok for the big question, Industrial Injection, or Blue Chip??? Are thier others out there.
Thanks for any input.
Gary
maybe it's the lift pump--can you hear it running when you bump the starter???... . www.jandhperformance.com or Winspeed 1-925-370-7245 are two places here in CA that I recommend---but where are you---J&H is in Redding and Winspeed is in Martinez----there's Craig Johnson down south also---chris
