Engine/Transmission (1998.5 - 2002) code 1693
Engine/Transmission (1998.5 - 2002) oil pressure question
Engine/Transmission (1998.5 - 2002) What does this sound like?
Hi everyone,
I would like some help in understanding what this code means?
I have cleared the computer a couple of times and it keeps
coming back.
My truck runs fine (good milage and power) just a bit puzzled.
Thanks Chuck
P1693 (M) DTC Detected in Companion Module A fault has been generated in the companion engine
control module.
P1693 (M) DTC Detected in PCM/ECM or DTC
Detected in ECM
A 9Companion DTC9 was set in both the ECM and PCM.
Its a generic code that means there was a problem between the ECM-PCM. It really means noting unless there are other codes with it.
