Engine/Transmission (1998.5 - 2002) code 252 and rough idle stalls and does not rev above 950 rpm
Engine/Transmission (1998.5 - 2002) Scheid Diesel VP44
2nd Gen Non-Engine/Transmission 2WD Air Ride Suspension
trying to figure out what this code is hard starting and idles rough max rev 900 rpm and sounds like hitting rev limiter i changed the fuel filter and appears to have plenty of fuel pressure
P0252 - Fuel injection pump fuel valve stuck :{
That is what my SMARTY manual says.
I've never heard of that on TDR.
Hope this helps.
John
PO252 - injection pump fuel mtering control A, range or performance problem [cam/rotor/injector] fuel valve signal missing [diesel models] Please fill in your signature by going under discussion forums at the top of the screen under user control panel..... click on edit signature & list your mods/info & click save. Then we can give you better info.
this truck is not part of mine that is why it isnt in sig block but it is a stock 99 w/ 150k on it (I am Spending soneone elses money on this )
As to the pump bad that is what i was thinking. I went to cummins website without ser number and tried to look code up was going back to oil level sender fault but not sure if these have that, and all of these codes for 252 did not affect performance from what i can tell. THANKS FOR THE HELP
