Code help please !!
Power Pup
Filter Minder???
I just changed my oil and oil filter, and the fuel filter. When I changed the oil filter I did it from the top and removed the intake tube. But when I was all done I forgot to plug in the little jack on top of the intake tube before I started the truck. That is the only thing that happened out of the ordinary.
Now my mill light is on and I'm getting codes. .
P0107 - map sensor
P0073 - ???
Help, what do I do ?
P. S. I checked all the jacks on the EZ and they seem to be good.
Jeff
The codes were set most likely because the sensor in the intake was unplugged. I did that once too. Just make sure it's plugged in now and the light should go out after a few start cycles. Re-check the MAP and IAT sensor plugs just to make sure they are secure, then drive it.
I agree with mberry. People are constantly reporting those codes from forgetting to reinstall the IAT sensor connector when they put the air box back in.
No problem.
-Ryan :)
Thanks for the quick replies ! It's definately not very hard to justify membership for this site !
One other quick question, is it a major problem to have a little too much oil in the crank case on these trucks ?
I had three 1 gallon oil jugs, I filled the filter and put the rest in the crank case. With about 1 quart left in the last gallon jug I checked the dip stick and it was halfway between add and safe, so I put the last quart or so in. Then after driving around to warm it up a little I let it sit for 20 min and checked the dip stick again. But now it was about 1/2" - 1" over the safe mark. So should I drain some or not worry about it ?
Sorry if my questions are pretty novice, but I'm just getting to the point on this truck where I do all my own fluid changes.
Jeff
I always put exactly 3 gallons in and it was perfectly on the full line. 1" above the full line might be too much but this is beyond my knowledge on these trucks. I do know that it's bad to overfill on my boats' engine.
No problem.
-Ryan :)
problem doesn't happen when you remove the oil filter from below and leave the air box and sensor as is ;)
and i have had a baro/map/iat sensor at the air box fail... if you throw that p0107 code and have no engine drivability issues under load between 1900-2000 rpm you are fine, and the code will reset its self. mine failed while driving and the engine develops a nasty stumble right at that rpm and the engine defuels heavily after that point, but still fuels enough to build full boost, just very slowly [i loaded the truck in 3th with the brakes on to see what it would do with the sensor nfg]
Well, I'm happy to say my mill light has gone off today ! I drained a little bit of oil to get it right on the top of the safe mark. I don't know why it took a little less than 3 gal. cause I warmed it up before draining and left the drain plug out for about 1/2 an hour. Not too big of a deal anyway.
Thanks for the help !
Jeff
Here is what the codes mean:
P0107=Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0073=P0073 Ambient Temperature Sensor High
