Code issue
TST PMCR went in tonight
electronics
As a matter of fact, I do have a code set - P0633, which is SKIM Key Not Programmed in PCM. Before I disconnect my batteries overnight, does anybody know what this means?
Dealer issue?
Originally posted by silverram03
It means that you have to get your ECM reprogrammed with your SKIM keys code number "the silver key you start your truck with. "
Hey, appreciate the response. I guess the dealer is involved if I want it removed, huh? What if I leave the code set or disconnect the batteries to remove it? It doesn't seem to be a problem. Do I need the ECM reprogrammed with the SKIM keys code number?
