I want to start by saying Hello as this is my first post after recently buying a 2004 Dodge Ram 2500 and so far the forum has been a great wealth of helpful knowledge! However after doing a solid chunk of maintenance to the truck I've hit a wall and can't seem to get past it. Any advice would be greatly appreciated!
I'm getting code P0088 (high fuel pressure at the rail) and a loud injector knocking sound.
Recent maintenance/upgrades include the following:
We bought the truck just a few months ago and the previous owner said they found algae in the fuel tank and that's when he had it professionally cleaned and the FASS system installed. So it does sound like the system was contaminated. We've run a few different fuel/oil cleaners (Stanadyne, ) in an attempt to fix the issue before we did this work and they kind of helped with the smoke but not the noise.
At this point it sounds like maybe the injectors are faulty or maybe the injector tubes aren't fully compatible... or even the CP3 pump could be failing. We're on the Big Island of Hawaii and the local dealership wants $300 to look at it. There aren't really any other diesel shops here unless we drive a couple hours so we've been trying other options but now we're stuck. Any ideas or suggestions would be GREATLY appreciated.
Thank you!
- Replaced the FCA (both new or old ones don't make a rattle sound when you shake them and there doesn't seem to be a difference in how the engine sounds if you disconnect the wire harness connector)
- Replaced the fuel pressure relief valve
- Replaced the fuel rail pressure sensor
- Installed new FASS fuel filters and dropped the fuel tank to ensure it wasn't contaminated. It's super clean and the FASS platinum system is only about a year old.
- Installed rebuilt injectors from InjectorsDirect.com (I know we should have gone new but this was all we could afford and their warranty seems legit)
- Installed new Cummins injector connector tubes (part #4929864). Though I did notice that the tubes look DIFFERENT than the old ones we took out.
Thank you!
