I have a friend with a 98 24 valve 5 speed that is cutting out, he said usually when stepping down on it pretty hard such as pulling a hill or passing someone. He is usually pulling a trailer but I am not sure if it does it empty also. I was thinking an APPS problem, but when I checked codes today it had p0234 for turbo overboost. He said the check engine light will come on when it acts up and go back out. I believe the truck has aftermarket injectors, turbo, airdog pump and a diablo powerpuck. Does the powerpuck do boost fooling? A picture of one looks like it has plug in for the map sensor. Truck has been set up this way for quite a while and he acted like it just recently started acting up. Will an overboost condition cause the truck to cut out like that?
Thanks for any suggestions,
Matt
Matt
