Engine/Transmission (1998.5 - 2002) Code p1693 and p0380
Does anybody know what these codes mean. The check engine light is on and it sometimes will go off for a day or 2 at a time. Thank you.
The P0380 is a grid heater fault... Possibly a wire knocked off a grid heater relay on the driver side inner fender (beside the power steering/injection pump).
Best of all, unless you live in the Arctic, it's not a critical code - if the grid heater relay is unplugged - or fails - the ECM senses it's failure, and sets the code - all that really happens in that case, is that the grid heater(s) won't work - not an issue above zero degrees or so...
Probably just a poor relay connection.
