It is a companion code. It just means that there is a code stored in one of the comptuers. When you scan the ECM, it just says there is a code in the PCM. It can happen in the other direction also.
The code 1693 itself means nothing.
If you have an '01 or newer, cycle the key on-off-on-off-on with out starting and wait. The odometer will show the P then E codes.
