old scout diesel
I have a 2015 3500 CC 2WD 6 Spd, and this code just showed up. The scanner says it’s “Redundant Pressure Too High “. What does it relate to? The truck has about 215,000 on it.
from what i have read use warm soapy water. Remove the injector from the system of course.
Just warm water works great.
Reductant Pressure Too High deals with the DEF injection system.
Do you have an OBDII scanner to see what the pressure is?
I would start by cleaning the DEF injector nozzle and clearing the code. If it comes back you may have to replace the DEF pump and/or injector.
Item 6 (upper right of diagram)Does anyone happen to know what size the DEF injector bolts are?
I need to clean my injector but the bolt heads have rotted completely off. Not sure how I will get the bolts out yet but I want to buy stainless steel bolts to put back in. I'm guessing maybe a 5 mm bolt? Not sure on length or pitch.
