Engine/Transmission (1998.5 - 2002) Code Questions
turbo dean
:) :) Hello To All, This Is My First Post And I Learned Something New Tonight. Just Learned How To Do A Code Check With The Ignition Key And P-pcu Came Up. Can Any Body Tell Me What This Means
Turbo Dean,
When the system goes nto the "display codes" mode, it lets you know what it's doing. First, it comes up P PCU, meaning it's checking codes in the powertrain control unit (PCU) computer. then it will either display the code(s) if present, followed by P Done. Next, it displays P ECU as it checks for codes in the engine control unit (ECU). Then, displays the code(s) present, then P Done again. It will then return to the odometer reading.
If all you see is P PCU, then ----------, then P Done, it meas there are no codes. Hope this helps!
