What is not working on the A/C (fan, compressor kicking on/off, no cold air)?
Are you sure that the system has Freon (134a) in it and at the proper level? You can pick up a set of Manifold Vaccum Gauges from Advanced Auto Parts for around $80 that will show you both the low and high pressure sides of the system. Depending on the outside temp, with the A/C on high, there should be around 30psi on the low side and around (I think, I would not know for sure w/o looking at a my gauge set) 200psi on the high side (engine @ 800rpm). Those numbers should increase in pressure as the engine speed increases.
No, those codes have nothing to do with the A/C.
-Rich
