Archived codes,and surging
Archived 07.5 no start.. VERy ******
Archived 2000 24v won't start
just bought another 2001,and its throwing a 1693,and a 234 code. on start up it takes 15 sec to get started and is slow to fire all cyls. while driving down the road the truck surges as if it is loosing 10 horse and does not do it at full throtle. any thoughts?
john
P1693 (M) DTC Detected in Companion Module A fault has been generated in the companion engine
control module.
P1693 (M) DTC Detected in PCM/ECM or DTC
Detected in ECM
A 9Companion DTC9 was set in both the ECM and PCM.
P0234 (M) Turbo Boost Limit Exceeded Problem detected in turbocharger wastegate.
Check fuel lines - could be getting air in causing long crank. Look at lines from VP to injectors especially at the nuts for signs of fuel leak = place for air to get in.
Do you have gages on this one yet? Verify LP psi not less than 10 at any pedal position is acceptable.
Keep us posted.
John,
Welcome to the TDR!
Try replacing the MAP (Manifold Air Pressure) sensor and see if that fixes the problem. The MAP sensor is located on the left/rear side of the cylinder head just aft of the fuel filter canister. Don't confuse it with the IAT (Intake Air Temperature) sensor, which is located even further aft on the left/rear side of the cylinder head.
Good luck,
John L.
My 2000 did the surging thing under light load and mild acceleration and was non existant with wide open throttle. The grounding solution from Suncoast Transmission solved the problem. Cut some wires, add a ground= cheap fix (for the surging, at least. )
I had a post about this in Truck 911 while I was on vacation pulling my fifth wheel. You will learn to love all the help you can get from the endless collective knowledge from the TDR Members! They will save your bacon!
