Engine/Transmission (1998.5 - 2002) Codes can you help
Engine/Transmission (1994 - 1998) Upgrade Questions
I've got a 2001 with a five speed manal, its been acting funny for the last 6 months. every now and then it will just have no power it lasts any where from 1 to 10 seconds then just takes off. Last night was the first time it gave any codes.
P0216 Injection timing control circuit malfunction
P1690 Manfacurer Contrl.
Auxiliary Inputs
Auxiliary output
I added a bullydog box a few months ago but it was doing this before that.
I am thinking its a crankshaft sensor. Im hoping someone can help.
Thanks T Brock :{ :{
Auxiliary Inputs
Auxiliary output
Your injection pump is headed south. Break out the wallet. :(
I'm afraid Bajabob is probably right. If the crank sensor was acting up the tach usually follows it (ie. 0 rpm).
Dave
Don't know of any sure way to test other than at a Bosch service facility. As for a new one I believe member Bob Wagner has them and probably as competitive as anyone else.
Dave
Get ready for a new VP44. You should check your fuel pressure and probably change your lift pump to try to prevent another VP44 failure.
JC
