OK Gang! Heading for the barn after 16k on the odometer for this latest trip from NC to AK and return! Two days ago while tooling through the flatlands of KS, get the “Electronic Throttle Control” light, shortly afterward the “Check Engine Light” Chimes in. I check the codes with my handy dandy code scanner, it states a fault with a Emission Sensor Low Voltage. Restart truck everything fine. Stop for the night in Dodge City. Next day ½ hour down the road, “Electronic Throttle Control” icon shows up, cruise control inoperative. About 15 minutes later, another chime occurs, this time the “Check Engine Light” appears. Then the overhead starts flashing “Catalyst Full, Service Required”. The “Electronic Throttle Control” starts blinking and we go into Limp Mode with a 30 ft 5’er through the rolling hills of southern Kansas. #@$%!
My Nagravator, locates a Dodge (Ram) dealer in Woodward OK, about 50 miles away. At a highway intersection I shut the engine off, I plug in the scanner and see P0471, P0107, P2228,C342D, P0055, C3064, C3064, C2174, C2520. I didn’t erase them, started the truck, Presto! The truck is running well!!!
Get to the dealer, he plugs in his equipment, asks about the Crankcase Filter, says the timers are all wacked out! Resets the timers, and tells me to drive steady without the Cruise Control for about 45 minutes at 55-65 mph while it’s going through a re-gen cycle, understood.
Truck has run fine since (2 days).Oo.
My question about the reset is, does this mean the system looks for another EGR Service in about 66k? What are all of the timers associated with? Note Specifics in Sig. Thanx in advance for any insight.
