Archived Codes/fuel pressure/turbo,HELP!!
Archived Truck down - need help! Injection pump?
Archived Stuck in Salt Lake City
Been haveing intermittant fuel pressure issues after trying 2 cycle oil(slow build up pressure at startup- 5 to 10 seconds to full pressure when its usually instantaneous) Changed filter seemed to settle down to normal.
Headed down the road to Santa Fe stopped after a couple of hours; on start up engine light stayed on and the fuel pressure started jumping back and forth from normal 8lbs to 0. On throttle dropped to 0 - on let up would recover; drove a little while thinking I'd head to Taos to get another filter; after a while pressure stayed up on throttle and droped to 0 on letup????
Stopped and to see what codes would come up: 1693 & 0237. Autozone computer says:1. Turbocharge control circut malfunction & PCM determined input voltage for boost pressure sensor A is too low for current engine opperating conditions.
So what does this have to do with my fuel pump pressure????Figured may bad electrical connection (some corrosion in the connection).
Cleaned off the pump electrical connections and disconnected batteries. After a couple of stop and starts the engine light stayes off and the pump pressure is more or less normal - maybe drops a little more than usual on throttle; but acceptable 6lbs.
Thinking its time for a good fuel pump to replace Dodges intank fix. But doesn't explain the codes which I'm still getting even though the engine warning light doesn't stay on.
Meanwhile engine runs smoothly without a hitch throughout???
The 1693 is a companion code. It meams there is a code in the ECM and PCM. The 237 is supposed to be low boost. I throw these 2 codes when I pull the fuel pump relay to crank without fuel on. Try cleaning connectors and swap the relay with another. If 8psi is all you have at idle normally, the LP is junk. You should have close to 15psi at idle and MINIMUM of 5psi at WOT. Less than 5 at wot eats injector pumps.
Geno's fuel filter top electrical guage. I hope so. Just got a mechanical Vulcan but its home and not installed yet. Wouldn't you know it!
Dseamans- yes cleaned the hot connnection on the battery terminal (there was some corrosion) and then as I said the engine warning light want off after a few starts. The codes are still there even though I disconnected the battery terminals. But I think they stay until after so many starts(?) and then reset? Either that or the problem remains.
The pressures are normal for the intank pump. But I think this is my excuse and wake up call for a Fass or something.
