2nd Gen Non-Engine/Transmission Codes
D
Engine/Transmission (1994 - 1998) Rear Wheel Sensor Test
Engine/Transmission (1994 - 1998) WIF sensor
Here People Talking About Checking Codes On Your Truck, By Turning Key On And Off. Need To Now How To Do It & Were Do The Codes Flash, Thank Guys.
turn the key on, off, on, off, and then leave on. codes read out on odometer. any codes will read out. then it will say p done. it think it only works on 2000 and newer.
mark
1998. 5 and older the codes flash with the check engine light in a sequence... the new odometer method is easier i think tho. .
to do it on either, turn the ignition on and off a total of three times, on the third time, leave the key in the on position (do not start) and watch the odo. You can also do a gauge check by holding in the odo reset button and turning on the truck, then releasing when it starts to do stuff. .
-j
