Go to the top of this forum where it says "24 valve FAQ" and there is a thread titled "THE 24V code list" at the very top, it lists all of the codes.
Or Click Here
P0500 (M) No Vehicle Speed Sensor Signal No vehicle speed sensor signal detected during road load
conditions.
P0500 (M) No Vehicle Speed Sensor Signal A vehicle speed signal was not detected.
P0743 (M) Torque Converter Clutch Solenoid/
Trans Relay Circuits
An open or shorted condition detected in the torque
converter clutch (part throttle unlock) solenoid control
circuit. Shift solenoid C electrical fault - Aisin transmission
converter part throttle unlock solenoid control circuit (3 or
4-speed auto. trans. only).
P1693 (M) DTC Detected in Companion Module A fault has been generated in the companion engine
control module.
P1693 (M) DTC Detected in PCM/ECM or DTC
Detected in ECM
A 9Companion DTC9 was set in both the ECM and PCM.
P1694 Fault In Companion Module No CCD/J1850 messages received from the powertrain
control module-Aisin transmission
P1694 (M) No CCD Messages received from
ECM
Bus communication failure to PCM.
I've heard that the P0500 can come from spinning the tires during slippery conditions and had it happen one time during a snowy period, I'm not sure though because I do burn outs once in a while since the dual disk install and haven't had it come in.
P0743 sounds like trans problems but I have a manual
P1693/4 are companion codes and just tell you that you have a code.
The only one I would concern myself with is the P0743, fix that and some of the other ones will go away, the P0500 I would clear and see if it comes right back, if not don't worry about it.
