Engine/Transmission (1994 - 1998) Codes
2nd Gen Non-Engine/Transmission "C" rated tires
Engine/Transmission (1998.5 - 2002) Buying an HX35
I threw a check engine light and not sure of the codes. I know one of them is disconnect of the battery and the 55 is end of cycle. I can't remember which is which. I threw a 12 41 37 and a 55. Any help would be great. I can't find a list of the codes.
Thanks,
Bryce
12= battery disconnected within last 50 key on cycles
41= generator field not switching properly (open or short)
37= torque converter clutch solenoid or trans temp high/lo
55= end of codes
Would air temperature be one of the causes for the 37 code? Also what field do you mean by the generator field not switching? Sorry for the hassle.
Thanks,
Bryce
