Engine/Transmission (1998.5 - 2002) codes
2nd Gen Non-Engine/Transmission Steering Box Leak
can anyone please explain what a P1693 code is ? I was traveling along the Highway when my truck bucked and slowed down briefly and then carried on for a short distance then stopped. I eventually got it started again and moved off the road to a parking lot. I did the key on and off three times and got P1693 code which translats to DTC detected in PCM or ECM. What does this mean?
Thanks.
Brian.
It's not uncommon to only get a P1693 when doing the key check. Brian, you'll probably need to get a code reader and hook it up to read what other codes were set. I think places like Pep Boys will hook up their code reader to your truck and show you the codes for free. Or you can get with someone who has a Smarty--I'm pretty sure those can read codes too.
I'm going through a similar problem--I've only got P1693 being displayed with the key check, and the truck is driving in limp mode with very little power. I'm pretty sure in my case it's either the MAP or IAT sensors are dead or dying, or my Edge Comp is on the fritz.
Good luck, and please post an update when you get it figured out.
Mike
thanks for the replies. I have decided to bite the bullet and take my truck to the dealership I will post the results when I get them. Thanks again.
Brian.
