Engine/Transmission (1998.5 - 2002) codes?
Engine/Transmission (1998.5 - 2002) Slight stumble and white smoke
Engine/Transmission (1994 - 1998) Valve and Timing Adjustment
Another code question engine light is not on but out of curiosity I did the key on-off deal and this is what it said p-pcu,0622,1765,1694 p-done p-ecu,p1639 p-done if any one can tell me what these mean and if it is something I need to worry about any info or suggestions would be great thanks Aaron
codes
here ya go
0622-generator field not switching properly--an open or shorted condition detected in the genorator field control circuit
1765-trans 12 volt supply relay CTRL circuit----an open or condition is detected in the trans relaycontrol circuit. this relay
suplies power to the TCC
p1694 (M) no CCD messages recieved from ECM-----BUS communication failer to PCM
service mmanual worth every dime!!!!;)
Thanks for the quick reply do you know where to get that manual? do you or anyone know if any of these are going to harm anything on the truck again thank you Aaron
