I know that this one has been gone over several times in the past but I have to vent.
Had the cold idle TSB done twice, the second time, which was about a month ago, the tech ensured me that he used the scan tool to enable the feature.
So last night it got down to 20deg so I thought that I would leave the truck out to see if it worked. Truck sat outside in the cold for about 12 hours and had not been drive (except backing out of garage) for about 4 hours prior to that.
Went out this morning and fired it up. Grids preheated for about 30sec and my pryo showed 32deg when i got in.
As far as I can tell all the parameters of the TSB were met. Truck idled for about 15secs as the grids ran and then the idle sounded like it was going to increase, it went up maybe 50rpm and no more. This may have been when the grids shut off though, i wasnt watching the alt meter. I let the truck run for about 5 minutes and there was no increase in the rpm.
How long and how gradual is the increase supposed to be?
Also does the above descriped weather (20degs and pyro showing 32deg) sound like it should have kicked in, or does it need to be colder? coolant was defeniantly under 140*
I hate going to the dealer ( for reasons like this) but I would like this feature enabled as my truck can sit for up to 18 hours un plugged when i am at work.
I would imagine that the scan tool they use is pretty expensive, does anyone know where one could be rented from so I could maybe do this myself?
Also is the temp picked up from the outside air temp or the intake air temp? Could one/both of these be bad maybe and fooling the ecm into thinking that it is warmer then it is?
Anything else I should check? How about the DD TTPM, any reason to belive that this may keep it from working?
any help would be appreciated,
Thanks
J-
Thanks
J-
