Hi,
I’m post this guestion for a friend which has a 2002 dodge 5.9 five speed. The issue is when the engine is cold you can drive down the road and the truck will stall and only go about 50 mph and you can try and accelerate but will not. He said you can slow down to around 30 mph then accelerate and it will speed up. Once the engine warns up it works normal. He has change the lift pump out and it’s acting the same.
Does anyone have any ideas on what could be the problem?
Thanks
Thanks
