Engine/Transmission (1998.5 - 2002) Cold start up question
after my truck sits for a day or 2, I start it up, within 5 or 10 seconds the truck will feel amost like it dies or stumbles, but catches again. It only last about 1/2 sec. It only does it once at startup, only when cold.
Tomorrow I got to remember to turn the AC off first, then try it to see if it does it. maybe its the compressor comming on, but its locked :mad:
My feer is its the injection pump going bad, and I leave Friday (I hope) for the 0uter banks (around a 9 hour tow)
anybody else remember having this problem Oo.
1998, built 7/98. 90,000 miles. I just put a lift pump on about 2K or 3K miles ago. Not sure where I could be leaking fuel in, all new washers, every where I cut the fuel lines on my "failed attempt" to put on a pusher pump is repaired with fuel line, 6" slide over line on each side of the cut, with 2 hose clamps each side.
I got all the compression fittings sitting in a bucket here that I could repair the steel line with more steel line.
It did not do it this morning. I left the AC off when I started it. For some reason I think the the stumble is really when the AC comes on the first time as the compressor seems to cycle on about 2 seconds after its started.
Thanks for the reply. Gives me something to think about.
If it was sucking air, I would think WOT would show signs of weakness? right now its running like it has a brand new lift pump on it :)
Originally posted by Evan A. Beck
Sounds like the fuel system is getting air into it... Check all connections and make sure they are tight. What year truck? Miles?
