I'm having problems getting my truck started in the cold. Anything under 40 degrees.
Plugged In
If I plug it in will start fine down to 20. Under 20 and above -10, it will sometimes start easy and sometime I have to go through 2 heat cycles (if the light will come on) Sometimes the I can't get it to start at all.
Under 20 I have to cycle the grid heater 3 times, then crank, I get some sputtering, repeat, same result, third time I can get it to light but sputters around 400 rpm for a couple minutes then lights off and runs fine. I have no problem starting it at any temp at lunch, but if I wait 9 hours or more. I don't know if I will be able to get it to start.
My set up is hot rod VP 44, stage 2 injectors, ats air horn, aurora 300 turbo, 201K miles
I've replace the batteries and that helped some.
I've replaced the startet (NAPA) did't really see any difference. it will crank the motor to 300-400 rpm.
I pulled out and tested the heater grid relays they work
I pulled out the heater grid, it works
I can hear the relay poping on and off with the wait to start light
No codes
Plugged In
No codes
