Yesterday while driving at 55 MPH, my truck just stopped running, like it is
starving for fuel. Coasted to the side of the highway, ended up having it
towed back to residence. I keep it plugged in on these cold nights, and know'
that only adds some warmth to the block for the oil. I believe what has
happened is that small amount of moisture gelled in my fuel filter. This '98 has 115K on it, I have owned it since late '07. It always runs what I call
very cool, unless I am towing temp gauge hardly moves off the cold mark, and when it does go up it returns back to original position. I didnt think it
worked when I first purchased the truck. A suggestion from someone while
I was on the side of the road yesterday was I either have no thermostat or it is stuck open. I haven't checked it. Question here after this lengthy para is what are other 12V owners experiencing in cold weather? Maybe I should be
adding something to my fuel. Had another person tell me out here that he puts in 1/2 of reg unleaded gas to every tank full to remove any moisture. Any thoughts out there? Other than this present issue I have been very satisfied with the truck. The KDP is blocked, I have no oil leaks anywhere, I use Amsoil Series 3000. New brakes, tires, new upper front ball joints, new carrier bearing, rebuilt rear end (limited slip), new transmission 20K ago), installed Larry B's contacts and plunger in the starter, Banks Stinger and Prime Loc relocated for the fuel filter. Supposed to warm above freezing tomorrow, plan to pick up new fuel filter from local NAPA and try starting it. Thanks for an responses and sorry for being long winded. Haven't posted anything in quite some time and am appreciative for the advice received in the past. From a cool central Oregon have a nice day. Tom
