Hello TDR brothers,
A bit of a lengthy explaination here, so please bear with me. '04 2500, 4WD, 35" Toyo M'T's, 77K, fluids, filters, faithfully changed @ 3-4K invervals. The problem occurs in temps below 32deg, the issue is can't-get-out-of-its-own-way power loss (unable to pull a 6% grade @ anything over 40MPH). EGT's are near 1500deg (normally 500-800deg), boost is maxed @ 23-26PSI (normally 30-32PSI). The symptoms usually clear up within 50 miles or when the ambient temp reaches 50deg or above. Mods or attempted fixes: BD silicone hoses (meticulously fitted/tightened), 4" Cone Engineering stainless muffler w/ tip, Westach combo boost/EGT on SRT A-pillar otherwise completely stock. Replaced MAP sensor, no joy. No codes, no smoke, no consistent power loss issues in warmer temps (I live in northern AZ), dealer has been unable to remedy the problem (in 3 tries). All fuel is purchased from busy locations and I've tried a variety of stations to eliminate bad fuel. The worst situation was driving a 2 lane, twisty, steep mountain road, under 25MPH, 20deg temp, had to pull over since it couldn't make enough power to travel 15MPH. Pulled over, shut down, restart, rev to clear the loaded-up fuel and was able to continue.
Thanks for listening, I'm trying to get this issue settled before next winter, any help is really appreciated!
