Combo gauge install ?
  • Thread starter Thread starter Samscov
  • Start Date Start Date
Pioneer wiring harness not available
S
Samscov
Guest
A Very Merry Christmas to all!
Where & how does the egt sensor mount that comes with the Geno's "Combo gauge" and where do You find a good spot to connect the boost gauge into the intake manifold on these "new-fangled" 24 valvers? #ad
Thanks.
2001. 5 ETH/DEE 2500 4X4 Q. C. SLT Lund Visor Owens Runningboards C R Laurence Power Slider & Others BUT NO POWERTRAIN BOMBING!!! (Thougt You would like to know that, D. C. )
"The Redneck Toy Box"
Samscov,
Merry Christmas!
The probe for the Egt sensor can go before the turbo in the exhaust manifold (have to dill and tap the manifold) or in the exhaust elbow. There is up to 300 degrees difference between the manifold and exhaust elbow (elbow location registers less temp)
Haven't seen the 01. 5 yet but there still must be the 3/4" plug right above the fuel filter housing that you and take out and replace with a 3/4" to 1/8" reducer that you can tap right into for your boost pressure.
Good luck.
Mike
Good luck.
Mike[/B]
Yes the 4/3 plug is right above the fuel filter on the 2001. 5 trucks. Easy to do.
Mark Schlueter
2001, QC, 4x4, ETC, K&N, White sport package. Kodiak Sidewinder Steps. Mag Hytec rear dif cover. Wet Okole seat covers. VDO Vision Gauges, A pillar mount from Geno's and Mag Hytec Trans pan are on order.
Thanks for the answers, I appreciate it!
Samscov,
Suggestion - while you have the turbo apart to drill the manifold, drill and tap the exhaust elbow (off the turbo) for a second thermocouple. You can plug it temporarily and order another thermo from Geno's and get a DPDT relay to put in line to measure pre and post turbo readings at the flip of a switch.
Good luck
'99 3500 4x4 QC 5spd. 3. 55 LSD K&N filter 18-11-99reflash,D-celerator E-brake
'99 26ft Gulfstream SeaHawk 5er 8000#'s Goose conversion(Colbert)
Originally posted by Jeff Alford:
Samscov,
Jeff, great idea as I will be dismantling and drilling the hole(s) this week or next week. You are right, I can always add the thermocouple later or just plug it and leave it. Cool #ad
Thanks
Mark Schlueter
2001, QC, 4x4, ETC, K&N, White sport package. Kodiak Sidewinder Steps. Mag Hytec diff. cover. Wet Okole seat covers with Rams head logo. VDO Vision Gauges. Three hole "A" pillar mount from Geno's. Westach gauges. Mag Hytec Trans pan is on order.
