In a "compression-ignition" engine, the engine compression has to be high enough that the air being compressed in each cylinder is heated so that when the atomized fuel is injected into this heated air that it will ignite. On a cold engine, the trick is to reach that point without very much temperature loss from the compressed air to the cool surfaces of the cylinder, head, block, etc. , so that combustion temperature can be reached. The starter has the job of cranking the engine fast enough for the cylinders to make the compressed air reach the combustion temperature at the same time the atomized fuel is injected. If all this occurs at the right time and in the correct order, ignition will occur, continue, and the engine should run. Our grid heaters assist this process by raising the temperature of the incoming air so that it will reach combustion temperature a bit more easily, especially with low or sub zero ambient intake air temperature. These grid heaters also help satisfy the EPA requirements of reducing "white smoke" or unburned hydrocarbon emissions during engine warm-up.
The advantage of the "electronically controlled" engine is that the fuel injection timing can be electronically adjusted to inject the atomized fuel at the precise point of maximum cylinder temperature for easier starting and allowing the atomized fuel to mix thoroughly with the compressed air molecules for more complete combustion during engine warm-up. The "timing advance" can also maximize injection timing for light loads part-throttle operation, heavy loads wide-open-throttle operation, and also during high engine RPMs when the fuel must be injected a little earlier in the combustion cycle in order to burn more completely and produce the maximum possible power.
With the P7100 "in-line pump", injection timing is fixed and has no "timing advance", and therefore the basic "static pump to engine timing" has to be compromised to find the "optimum compromise" point to get as much power as possible out of the engine, but also allowing for easy starting.
Everyone is correct. In a nutshell, that's what happens. Certainly not a technical dissertation or a complete scientific explanation, but I hope it will help...
