comes out of o/d at 70 mph
tough choice question!
Source for '91 Ram 250 front disc/hubs?
92 w-250 4x4, 518 trans. pro-torque convertor and shift kit. At about 70mph the trans will come out of o/d when you partially back off the pedal, like at the crest of a hill. I adjusted the throttle position sensor and it cured 90% of the problem. Usually did not kick down above 65mph. Is the t. p. i. on it's way out? By pass linkage is in the best spot so far. Any input appreciated. Mike.
92w250 club cab auto 16cm 3. 5exh. 50gal aux. k+n 30+psi boost 4 guages
I would check speed sensor on the transfer case. I had similar problem with mine.
93'4+4 LE emerald green Banks PowerPack,Cummins crome
On my '92, the connector connecting the harness to the TPS wasn't making good contact and making the O/D erratic. I cleaned the contacts and spread them a little to make a little tighter on the plug and it stopped the erratic O/D clutch enganing/disengaging at different speeds. You might try and see if that helps.
Bill
Y2K 3500QC, 6 Speed, 4. 10, SLT+, Camper & Tow Pkg. , Westin Chrome Nerf Bars, Mopar Flaps, Reese 20K Hitch, V-A CPC, EGT & Boost Gauges, RPM 45 Gallon Aux. Fuel Tank, Highway Products 5th Wheel Toolbox, ECM Controlled PacBrake, Painless Wiring Kit, Mag-Hytec Diff. Cover, 80% Towing Hitchhiker II 31', 2 slideouts, 19,750 GCW, Coming Soon: Rancho 9000, Lance 990 Camper
