I put about 100k per/yr on. My last two batteries have lasted about 2 yrs
each. Same symptons ea. time. Battery is overgharging. New regulator. Tested alternator is Ok. Charging at 16V steady and boiling the water out of the battery. Does high miliage per/yr shorten the life expectancy time frame ? If not why does the Regulator allow 16v to the battery when the tech sheet says it will allow 15. 1V Max ? R C
