Engine/Transmission (1998.5 - 2002) common rail swap
i have a 2002 that a bearing has let go in the motor i have a 2003 common rail motor and the truck it came out off how hard wud it be to put the 03 motor in the 02 truck has anyone done it or can it be done with out alot of switching and it being a pain
Lot of physical and electronic differences because of completely different injection systems between the two. You would have to either make it like a '98. 5-2002 engine by getting a special timing case and converting it to VP44 and installing a VP44 pump replacing the injectors to VP style and getting special adapter crossover tubes. But then I'm not sure about some of the electronics like tach sensor to tell the ECM engine RPM and so forth.
The other approach is make your 2nd Gen truck common-rail ready which would involve adapting sensors, wiring and setting up a common rail ECM. Bob Wagner could probably assist with that piece of the puzzle.
If you do a search for posts by member RRamsey you will find 4-5 threads he started about swapping a common rail into a 12-valve truck which turned out good. Unfortunately he's not a member here anymore.
https://www.turbodieselregister.com...sions/205768-starting-my-commonrail-swap.html
https://www.turbodieselregister.com...-conversions/206299-finished-finally-wow.html
Vaughn
