HEUI- Hydraulically activated, electronically controlled, unit injector... that being said, HEUI injectors use motor oil at high pressure (the cats run 870-3200 psi if i remember correctly) now an oil pump pressurizes the motor oil and feeds it to each injector, and an electronic control solenoid allows the oil to "hit" the injector, multiplies the fuel pressure on the other side of the piston about 6 times, and increases the fuel injection pressure to as much as 24000 psi. common rail systems (to my understanding) utilize a high pressure rail, to electronically controlled injectors, the pressure is not developed in the injector itself like a unit injector. the electronic control simply allows the fuel to act on the injector needle, and the fuel pressure opens the injector, and the lack thereof (when the control closes) stops the injection period. the major difference between the HEUI and the common rail is where the fuel pressure is developed, one in a fuel pump supplying the rail, and the other in the injector itself
Tim
