Engine/Transmission (1998.5 - 2002) comp boost elbow
Engine/Transmission (1998.5 - 2002) FASS does its job!!
when i installed the comp, i first left the stock boost elbow on and was getting around 26 psi boost. i installed the elbow that came with the comp, and now all i get is about 13, or so says the guage. the comp elbow simply has a smaller orfice, so am i really only getting 13psi, or is it just causing a inaccurate reading on the guage. should i go back to the stock elbow? i didn't seem to notice any power difference between the two, and the turbo seems to spool equally with either elbow.
If anything, the boost should go up with the elbow. Sounds like you might have a leak somewhere (maybe in the wastegate hose since that's what you fooled with?).
