The Comp is on and now (after all this bombing
)I have an EGT problem. I know, it's inevitable but that little HY35 has been doing a good job until now
This problem occurs around level 3 on the open road. It's all dependent on how I run it but one time when I was passin a truck on level 4 I hit 1500 for a split second (Whoops) so I backed her down a little and EGT's were back to manageable.
With the DDII's, an EZ, straightpiped. EGT's never got above 1100 degrees. The comp is what pushed it over the edge
So now that I have an EGT problem, what do you guys think about a PDR HX35??? Does it really spool almost as fast as an HY??? And should I bump the exhaust to a 4" from my stock exhaust that's straight piped??? I may also have to change my intake. I don't think the small version of the BHAF is cutting it anymore and I'm thinking of an AFE or Scotty?
I think I know what I'm going to do. I'm just looking for an economical solution. The Comp was supposed to be the last Bomb for a while.
