cause without being tapped you get no additional fuel
This is not true. When I turn the box on, the power and smoke levels dramatically increase. And the response and off boost smoke increase with each sub level. You still get roughly 60hp without the wire tapped.
I agree with your second statement. The fact that it doesn't work on my truck is what I am trying to figure out. The boost fooler is obviously working, because I run 55psi and it doesn't defuel. And I would venture to say the MAP is working, at least somewhat, because when I unplugged it, I had very obvious results.
Other than this "trick" not working, my truck runs great and everything appears to be fine.
Dan
