OK, hopefully that title was descriptive enough. I have an Edge Comp with FBD 150 injectors. When I stack a Smarty and go WOT the truck starts missing around 2200 rpm & boost hangs at about 32 psi. If I leave my foot on the floor it will clear up around 2700 rpm & run on out. When I do this I get a CEL & P0251, P0632, P01693 codes. I know the 1693 & 0632 codes are inherent to the Smarty, but the P0251 code seems doesn't make sense. Of all the posts I read about P0251 trucks either just died, or would not start. Mine only throws this code with the Smarty, and only when it misses. Question is, what could the root cause be of the miss & P0251 code? The IP is 2 years old & was purchased from Diesel Performance Parts in Nashville.
