Hello everybody! I have a 2001 W2500, HO, 6 speed, Quad cab, and I am going to be removing the trans and transfer case as a unit for clutch replacement. The complication that I am running into, are the two metallic vacuum lines that are running on the top side of the transmission mounting bracket. These two lines go from the passenger side down over and across the top of the bracket just aft of the forward lip on the bracket. In the process of removing the transmission and sliding it toward the rear and dropping it down, this movement will surely bend up these small vacuum lines. Does anybody have a technique for removing the transmission without damaging the lines, or do you just give them a little bend down to avoid interfering with the transmission? Thanks for the help!
