So maybe I had too much spare time on my hands today. But I got to looking at the compressor map at the Garret Website and I got curious. I (a friend and myself) immediately figured how to read the chart, but found it of no use. This is because I had no clue what CFM (expressed as lbs/min on the chart) the engine was pulling at a given RPM and boost pressure.
Surfed the web, discovered out how to calculate "equivalent" CFM at various boost pressures vs engine RPM. Added this conversion to the Garret chart and got amazed.
If the Garret sales people did not doctor this up too much from the engineering people it shows that stock turbo just about perfectly fitted to the engine. I assumed that the chart showed a HX35 SO (235 Hp) it plots out right in the middle of the chart where I would place the highest efficientcy island.
What I came up with is at 20 psi boost (with a 90% Volume Efficientcy):
1800 RPM = 398 CFM (60 MPH)
2000 RPM = 442 CFM
2200 RPM = 487 CFM (a little over 70 MPH)
These CFM numbers cross sit right in the middle of the compressor map chart. If you look at the stock torque curve this is where the engine is designed to build torque. Pretty smart, right?
So once again, I get myself confused. If one wants to add injectors, electronic boxes or what ever to increase stock Hp then one must also increase air flow. This means getting another turbo to control EGT's.
How would one go about doing that to match a turbo up to the Hp increase?
I kind of envisioned that it would require setting the waste gate at a pressure that crosses the compressor map at a spot where the turbo runs at the most efficient area and with the engine running at 1800 to 2200 RPM.
Other than trial and error, word of mouth how would you really know that this turbo over that turbo is the one you need?
And will this really ad up to controlling EGT with the Hp the engine is putting out.
Thanks for any replies;
Jim
2000 RPM = 442 CFM
Jim
