Hello All, I'm new to TDR but not to Dodge/Cummins! I have an 89 350 with 195m + miles. My question and I'll share some experiences; What is the normal compression in lbs for this motor with 150m plus miles? Mine has numbers from 340 to 380 dry and each cyl jumped 15-20 lbs oiled out. Now I have this to mention; around the 160-70m I changed inj nozzles, the motor was down in power is why, when I did that a serious miss type situation was obvious, but it ran like a new motor at road speed, just idled like a full race cam in a dragster. So next I was advised by Cummins I needed an inj pump rebuild, no change after that money went out of my possession, next a tech at a Cummins said I have air in the fuel system and he determined this by cracking the nozzle lines while motor idling, no change in motor on several. I've replaced lift pump several times and had some of the nozzles exchanged. Like I said, it runs like a champ going down the road with a full package but slobbers, overfuels, idles rough when cold, a little smoother when warm. My money is on compression is low when cold but would like to hear from others, especially like to know the compression poundage. Anyone looking for a clean 89 for a restoration?
Tom
